Threshold with LSH and BMI
edubht
#1 Threshold with LSH and BMI
Beitragvon edubht » Mi 27. Jul 2011, 18:22
Good afternoon.
I would like to inquire about LSH programming and bmi.
I have scheduled two thresholds.
The intention is to light a 100% light, 50% or 0%. depending on the threshold and bmi.
Programming is performed as follows:
B1 (Threshold 1)
MAKE: LED10 ON
BREAK: LED 11 ON
MAKE: LED11 OFF
BREAK: LED 10 OFF
B2 (Threshold 2)
MAKE: LED11 ON
BREAK: LED 12 ON
MAKE: LED12 OFF
BREAK: LED 11 OFF
B4 (BMI)
MAKE: LED 9 ON
BREAK: LED 9 OFF
BREAK: light off ramp 9 seconds.
Logic:
And C1 (led 9 - led 10)
light off
And C2 (led 9 - led 11)
50% dim light.
And C3 (led 9 - led 12)
100% light.
The problem is that the lsh is near to the lights, and when the light turns to 100%, the threshold changes, and light up to 50%.
I tried to lock the keys C when light comes on and unlock when turned off, but it has not worked properly.
What solution do you recommend?
Best regards.
#2 RE: Threshold with LSH and BMI
Beitragvon Uwe » Do 28. Jul 2011, 01:00
Moin :w00t:
Change the threshold to a value which is not exceeded even when the light is on.
Otherwise it must be converted the light sensor to another location (away from the lights).
Lock keys do not even work from my experience too.
Best regards
edubht
#3 RE: Threshold with LSH and BMI
Beitragvon edubht » Fr 29. Jul 2011, 11:36
Moin!
Why not working properly lock keys?
I can not change the location sensor to Another.
if I Change the threshold to a value not exceeded Even Which is when the light is on.
In what moment are added back?
example:
threshold 1 300
threshold 2 200
when the low threshold 2. if bmi detects presence. 100% light. the brightness changes to 350. I rest to the threshold 2 the value 200.
In what moment are added back the 200?
Best regards
#4 RE: Threshold with LSH and BMI
Beitragvon Uwe » Sa 30. Jul 2011, 19:25
You will have a time problem in the execution - and have to watch very carefully to your timing. Small numbers / letters always take precedence over big, you can see the execution in the bus monitor. It is OK, but you have to look closely.
I think the better way ist to convert the light sensor to another location.
buena noche
Zurück zu „Programmierfragen“
