Base & SONOS
DOMIQ
#31 RE: Base & SONOS
Great. For SONOS, we actually have SOAP stack inside the Base, so it's not very complicated internally. It's more effort in actual mapping of UPnP variables into channels and commands, that would be easy to use and powerful.
#32 RE: Base & SONOS
Do you have a tutorial or examples of the UPnP-channels?DOMIQ hat geschrieben:It's more effort in actual mapping of UPnP variables into channels and commands, that would be easy to use and powerful.
#35 RE: Base & SONOS
Sonos, direkt vom Base steuern, hätte was.
Im Moment behelfe ich mir mit macros auf der LinHK,
die hinter Tasten im LCN liegen, und vom Base ausgelöst werden.
- 470841Foto.PNG (26.78 KiB) 4325 mal betrachtet
#36 RE: Base & SONOS
Ein LinHK Beispiel für einen sleeptimer (5 Minuten) per BMI ausgelöst :
sleeptimer.txt:
buero_play.txt:
Makro :
Spielt den letzten eingestellten Sender.
sleeptimer.txt:
POST /MediaRenderer/AVTransport/Control HTTP/1.1
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#ConfigureSleepTimer"
CONTENT-TYPE: text/xml ; charset="utf-8"
HOST: 192.168.1.37:1400
Content-Length: 422
0
0:5:0
CONNECTION: close
CONTENT-LENGTH: 266
CONTENT-TYPE: text/xml; charset="utf-8"
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Play"
01';
#! /bin/sh
# Timer 5min
cd /var/media/NEW_LINK/linhk
./netcat 192.168.1.37 1400 /dev/null
./netcat 192.168.1.37 1400 /dev/nullgruss thomas
DOMIQ
#37 RE: Base & SONOS
I will quickly add SOAP and HTTP calls API for Logic.
It's not as nice as what we plan, but time flies and this would be usable for other things as well.
One thing I need to assure, is that it is loaded only when used, not to waste memory I all Bases...
DOMIQ
#38 RE: Base & SONOS
OK, I took the challenge!
Next week we will have first beta of proper SONOS support.
