Android
DOMIQ
#31 RE: Android
Beitrag von DOMIQ »
Here is the beta 2 of the Remote for Android http://www.domiq.pl/data/AP/domiq-remote-0.2.0.apk.
You will need latest system to use it. There might be problems with connectivity using server, as we fine tune protocol details and firewall bypass. There is no temperature history and remote camera views, both will be added later.
Matthias_@_Home
#32 RE: Android
Beitrag von Matthias_@_Home »
Hey, Thanks a lot!
I installed it and connected. it looks great!
Tomorrow I will test it
regards
Matthias
koboldo
#33 RE: Android
Beitrag von koboldo »
Thanks :w00t:
Local it works....But over the Internet it doesn´t work, or do you ment that with: "There might be problems with connectivity using server"
DOMIQ
#34 RE: Android
Beitrag von DOMIQ »
On some routers it will not work, we are working to resolve it...
Matthias_@_Home
#35 RE: Android
Same Problem on my Station.
I found a little bug. The selection function does not work.
i use on/off to start the event.
but in the android App i can´t unselect one of the buttons.
now both are activated.
koboldo
#36 RE: Android
Hi Filip,
I have the "famous" FritzBox if I can help or test something....
Regards
koboldo
#37 RE: Android
Hi Filip,
bei der Remote weren Themes aus meiner Visualisierung falsch angezeit...
Mein Theme für die Rolläden, zeigt bei Sonnenschutz der Rolläden auf 65% einen Rolladen mit Sonne an. In der Remote App wird allerdings ein Fragezeichen angezeigt....siehe Screenshots...
[img]2[/img]
603101Android Remote.jpg (5.31 KiB) 4184 mal betrachtet
domiq-mj
#38 RE: Android
Beitrag von domiq-mj »
Hi koboldo
Thanks for your feedback. Can you please send me the graphic control (a theme file) you have problem with on my email: mjonik at domiq.pl?
Is this the only control your're having such a problem with?
koboldo
#39 RE: Android
Hi Michal,
you have an email....:rolleyes:
Regards
koboldo
#40 RE: Android
Mir ist noch aufgefallen, das Filip gepostet hat das wäre die Version 0.2.0, im Startbildschirm steht bei mir aber 0.1.0.....
Des weiteren habe ich öfter Probleme mit dem connecten....dann muss ich die Daten löschen und wieder neu pairen, dann klappt es wieder...
Handy ist ein oneplus one mit Android 4.4.4
