Even if it stays on the list the information assiciated with it is deleted
(pairing, configration, cached images, etc).
So after re-run it will start collecting the new details based on the
search responses, pairing and configuration (once successfully connected).
You can manually clear all the application data as for any other application which is described for example on this page.
If I understand correctly, it keeps asking you for the PIN code?
Do you have latest available updates installed on your Base?
Android
#62 RE: Android
Of course i have the best updates on the Base
There is no answer/requester for the PIN code ...
Log says
Log says
12:59:28 INF SRV.DEA Starting ECC server key generation for 192.168.177.21:60518
12:59:29 INF SRV.DEA Key generation completed
12:59:30 INF LOGIC 12:59 - 22.09.14
12:59:32 INF SRV.SDP Got UPNP M-SEARCH request from: 192.168.177.10:33558
12:59:37 INF SRV.SDP Got UPNP M-SEARCH request from: 192.168.177.10:33558----------------o00o----'(_)'----o00o---------------------
#63 RE: Android
THX Michal - great job
@Thomas: gib mir den Code und ich mach dir das Licht aus B)
Nighty Night, Uwe - der sich den Code auch selbst holt
#64 RE: Android
Thanks Uwe for your collaboration!
I will include the fix in the next offcial beta release.
Lowrider54
- Einmalposter
#65 RE: Android
Hello
First of all: thx for finally programming the Android app!
I have the same prob that Uwe described but unfortunately did not get the point for solving it. I never ran remote and do not have aclue whether my small remote does anything or not but the app never asks for anything, it only tries to connect without success.
What did you do?
Regards
Lowrider
What did you do?
Regards
Lowrider
#66 RE: Android
New version of the Beta application is now available: http://www.domiq.pl/data/AP/domiq-remote-0.3.3-dev.apk. Michal is now on a short vacation, so he will keep fixing things when he is back...
koboldo
- Hat sich bedankt: 7 Mal
#67 RE: Android
danke für die neueste Version :thumbup:
Es gibt aber immer noch Probleme wenn man eine Verbindung über VPN herstellen möchte.
Dann wird das Base nicht gefunden und steht immer auf connecting. Wenn ich über das + die IP des Base dann manuell eingebe, findet
er es sofort. Vermutlich sucht die App nur in einem bestimmten Range nach dem Base.
z.B. wenn man zu Hause im lokalen Netzwerk den Range 192.168.178.20 - 192.168.178.200 verwendet und das Base die IP 192.168.178.22 hat wird beim lokalen verbinden das Base sofort gefunden, wenn man sich aber per VPN verbindet, erhält man über den VPN Servert z.B. den Range von 192.168.179.0 - 192.168.179.999 und somit sucht die App vermutlich nur in dem Range 192.168.179.0 - 192.168.179.999 und findet das Base nicht...
#68 RE: Android
Ich habe zwar noch keine laufende LCN - Installation und auch keine Base. Es sieht mir jedoch nach einer typischen Netzwerkfrage aus. Kannst du irgendwo (z. B. Der App oder VPN config) die netzwerkadresse angeben? Dein VPN liegt nämlich in einem anderen Netz als die Base und der "Suchradius" (broadcast) ist standardmäßig immer das eigene Netz. Kann auch sein, dass Du Deinem Router mitteilen musst, dass er Broadcasts auch in andere Netze erlauben soll.
Ähnliche Probleme wie du mit der Base sind auch mit wake-on-lan über WLAN oder repeater bekannt und die Lösung ist die gleiche.
Mathias
Mathias
Viele Grüße,
Mathias
Viele Grüße,
Mathias
koboldo
#69 RE: Android
Das ist wohl das Problem (nur anders beschrieben
) Ich denke aber mal das ist ein Problem der App, VPN und lokales Netzwerk müssen ja zwei verschiedene Ranges haben....
Wenn ich dann in der App die IP eingebe findet er das Base ja auch B) Nur diese wird anscheinend in der App nicht gespeichert, so das beim nächsten mal wieder dort gesucht wird...
#70 RE: Android
Ich sehe kein Problem, Jörg.
Meine App habe ich problemlos (durch Eingabe der IP) mit dem Base von Thomas über eine VPN-Verbindung auch pairen können.
Die Verbindung ist bei mir gespeichert und funktioniert immer wieder ...
