Yesterday we published an update for Base modules. The main feature of this update is integration with Shelly devices.
Full list of changes: https://domiq.eu/news/update_2.0.4.0
Tutorial about integration with Shelly: https://domiq.eu/tutorials/tu_0029
Integration with Shelly | Update: 2.0.4.0
DOMIQ-Support
BerndKorzineck
- Schon länger hier...
- Hat sich bedankt: 1 Mal
#3 Re: Integration with Shelly | Update: 2.0.4.0
Great job! Works good and easy to configure!!!
Tested with an Shelly One V3.
BerndKorzineck
#4 Re: Integration with Shelly | Update: 2.0.4.0
I already have a problem...
As soon as a Shelly module is de-energized and then reconnected to power, you cannot send a switching command via MQTT from the DOMIQ. If you switch to the web interface on the Shelly module itself, the status is displayed on the DOMIQ. However, switching does not work on the DOMIQ after a power failure on the Shelly Module.
#5 Re: Integration with Shelly | Update: 2.0.4.0
I have the same problem. After rebooting the Base every think works fine.
Zuletzt geändert von norden am Mi 3. Aug 2022, 23:06, insgesamt 1-mal geändert.
DOMIQ-Support
#6 Re: Integration with Shelly | Update: 2.0.4.0
BerndKorzineck hat geschrieben:I already have a problem...
We will check this, because we haven't observed such behaviour during testing.
UPDATE 1: We checked it and it's as you reported. This is a bug in Shelly devices - they do not send the MQTT disconnect packet as required by the MQTT standard. Only the 1st generation of Shelly devices have this issue. The 2nd gen. devices behave properly.
We will include a patch to handle this in Base.
UPDATE 2: Issue is already fixed, we will release minor update ASAP.
Zuletzt geändert von DOMIQ-Support am Mi 13. Jul 2022, 12:01, insgesamt 1-mal geändert.
DOMIQ-Support
#7 Re: Integration with Shelly | Update: 2.0.4.0
Besides this issue, what are your first impressions regarding using Shelly with Base?:)
DOMIQ-Support
BerndKorzineck
#9 Re: Integration with Shelly | Update: 2.0.4.0
DOMIQ-Support hat geschrieben:Besides this issue, what are your first impressions regarding using Shelly with Base?:)
Super easy integration into DOMIQ.
So far, Shelly One has been implemented as a single switch and Shelly RGB2. Here I have already written my positive experiences in my post from July 11th, 2022.
viewtopic.php?f=8&t=7597
Andre-sv650
#10 Re: Integration with Shelly | Update: 2.0.4.0
Wow,
i have not expected such a big change. I have no shelly devices, but what i have seen is, that they are not expensive and the integration is now super easy.
I think i will buy some and check it, LCN is really expensive and for example there is no plugin with current measurement.
Really a big thanks to Domiq for the support and the update.
Andre
Andre
